Hair & Fur Render Error: Unhandled Exception: Broadcasting NOTIFY_POST_RENDER
Tags: None
Hi Vlado,
I do have mesh lights. I have turned them off and still the same problem.
So I turned all the lights off and it still crashes.
ok.
How should I get it to you?
Well, I don't need the whole scene, just some part of it that reproduces the problem - you can send it to vray@chaosgroup.com
Just emailed a link to dowload the file.
Thanks.
Ok Problem solved.
The VrayLightMaterial's were causing the problem. Will render them in seperate pass.
You can still render objects with VrayLightMaterial. All one needs to do is Turn of Visible to Gi, and Generate & Recieve Gi.
