Lighting problems
Thank you verry much Morne,
this works fine, But i still have trouble with the light downe the windows.
i post with this the corridor view with the problem fixed and a crop of the problem in the other view.
I have try to play with the sample size of the light cahe but it doesn't change anything?
if you have an idea...
Thank you.
hmmm different approaches for this, maybe a combination of things.
try any or all of these:
pull sill vertices into the wall
in irmap, tick "check sample visibility"
if still no luck then also in irmap tick "detail enhancement"
how's it looking now?Kind Regards,
Morne
Yes!...
thank you again Morne... here is the result
01 Check sample visibility (the best ans the faster)
02 Detail enhancement
03 both
i have bring down the irradiance map preset to medium. before this i have try to play with the clr tresh, Nrm tresh and dist tresh, and i have noticed thet it doesn't fixed the problem.
So....
thank you, always a pleasure to learn something, and to find help
