render element mtlid
  • render element mtlid
    Should the rendermtlid element work right out of the box or do I have to assing material ids manually? I always get just black screen when I enable mtlid element. I read somewhere that it should work automatically. I have once rendered the element right and got all the mtlid's showing in different colours, but after that it has been just a black screen. What is the right way to get it working?
    In Maya, you must to add a material ID manually on your shaders (or shading group).
    I don't know if it is the same in 3dsmax.
    But in Maya, we have script which generate unique materialID based of the name of the shader. So, it is automatic.
    www.deex.info
      You need to explicitly set the IDs of your materials from the material editor.
        Ok. Thx. I'll give it a test during the next render. Is there similar plugin for max2012 that bigbossfr is using for maya?
          do a quick search on scriptspot, there's a bunch of them that will do what you want
          Kind Regards,
          Morne
