Weird VRay2SidedMtl issue
  • Weird VRay2SidedMtl issue
    Even though I've gotten through the project I thought I should bring this to your attention.
    I have a simple animation. It's just a cube doing a linear 360° turn over 60 frames. It has a VRay2SidedMtl on it, and a VRay Light inside to give it an animated glow. It's viewed from a camera that is looking down on at at 60°.
    For some reason the material will not render on frames 15 and 45. I was able to get around the problem by adding rotation keys on those frames that were just 0.001° off from where it is on those frames.
    Shall I send you the file, or is this an issue you're aware of?
    - Geoff
    yes please post it.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Ok. I can't seem to get the uploader working. What e-ddress shall I send it to?
      - Geoff
        The issue is with the rotation of your light. If the sphere light does not rotate, it renders correctly. However I still think its a problem, will pass it on to the right people
        Dmitry Vinnik
        ShowReel:
          Ah! I forgot that I had that linked to the cube (not that it really needed to be).
          - Geoff
