frame stamp font size
  • frame stamp font size
    I cant seem to change the font type and size on the frame stamp it just renders with the default settings :/
    Please confirm the exact V-Ray version installed (full name of the installation file) to test with.
    Tashko Zashev | chaos.com
      V-Ray 2.20.01 and 3ds Max 2010.
      *edit* It doesn't work after loading a render preset. However if inputting settings from scratch it works.
        Frame stamp and load/save presets work fine in our tests, If you post a step by step setup to reproduce it will be helpful.
          I have attached the render preset. If I try and add a frame stamp once the preset has loaded I cannot change the font size. V-Ray Start.zip
            I can reproduce this here and we'll look into it, but in the meantime you can change the font directly from the VFB (the "F" button on the stamp toolbar) and this works fine.
              Great, thanks vlado
                A suggestion: Would it be possible to save the frame stamp data as metadata in the file directly? Like the exif data in a digital photo. I would find that extremely useful.
                www.whiteview.se
                  Will add it to the "to do" list and we'll see.
