warning : T "M" (R) is not compatible with V-Ray and may cause problems
  • warning : T "M" (R) is not compatible with V-Ray and may cause problems
    Hello,
    When rendering, I see this message appear in the vray log window :
    It doesn't prevent rendering, but I'm curious to know what is T "M" (R). How can I find out if it's a plugin, a map, an object, a modifier ? I have no clue what it is.
    Thanks
    mekene
    It's probably a raytrace map or a raytrace material.
      Oh yes indeed. A simple convert scene to vray solved the problem !
      Thank you.
      mekene
