Animated Imap - splotchy
  • Animated Imap - splotchy
    Any idea why the moving splotchyness on the car?
ID:	876731Click image for larger version
ID:	876732Click image for larger version
ID:	876733Click image for larger version
ID:	876734Click image for larger version
    You have to give us more details about your irradience map setup. Irradience map in general does not play well with moving objects, there are some specific methods you need to use to make it work correctly.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Prepass
      IMAP:
      -3,-1
      50, 20
      interp frames: 2
      mode: Animation (prepass)
      use camera path ON
      LC:
      900
      .02
      single frame
      use camera path ON
      Render Pass
      IMAP:
      -3,-1
      50,5
      interp. frames: 2
      mode: Animation (rendering)
      LC: OFF
        to me it looks like there is something wrong with your irradience map, you dont have to look at the multiple number of frames to see that there is strong splotchiness on the vehicle. I think once you resolve the splotchy feel on the car on a single frame, it will look better on the moving frames.
        Dmitry Vinnik
        ShowReel:
          What setup do you use to lighten your scene?
          Probably the Hsph. Subdivs value is too low for the camera path, try to increase it.
          Can you post your settings for V-ray DMC sampler also to be sure that this is a GI issue you can add VRayGlobalIllumination render element.
          What is the V-Ray version that you are using ?
          Tashko Zashev | chaos.com
            There were some issues with models from CAD programs where the actual geometric normals on the surface would be inverted relative to the smooth surface normals; this will confuse V-Ray and might lead to artifacts such as yours. But then again, it might just low hemispheric subdivs for the irradiance map.
