Render wrong buckets, looks a little correct but not 100%
  • Render wrong buckets, looks a little correct but not 100%
    Hi.
    I have a problem with my renders. Some buckets does not show up correct. What can be the problem.?
    https://www.dropbox.com/s/qmuuzij21j...0buckets.PNG?m
    www.3D-Vizual.dk
    Are you using distributed rendering? Looks like some of the render nodes can't find the textures. (Or they have different vray versions.)
    www.whiteview.se
      Yes. But I have latest Vray on both.
      when I render with lower settings, I don't have the same problem.
      www.3D-Vizual.dk
        Do you have any warnings in the V-Ray Log screen?
        Be sure that all additional plugins (if such are used) are installed to both of the machines.
        Do you use a preset for the lower settings?
        Tashko Zashev | chaos.com
          I think I might have solved my problem.
          I had to update my forest pro on the render slave.
          But know I am dealing with crashes during rendering. Almost at the end of the render
          www.3D-Vizual.dk
