Hair and Fur error
  • Hair and Fur error
    I have a scene with a plane in it. The plane is extruded at the sides and then I have a hair and fur mod on it. Whenever I try to render the attached error pops up.
    Any ideas ?
    Regards
    Steve
    My Portfolio
    Can you post the scene?
      I cannot post the full scene because it is a project in process and has a lot of proxies etc. I have found that if I have the rug isolated with a few other bits it renders fine. If I try rendering the full scene with all proxies it will always crash. It seems to be a memory issue.
      I can send just the rug on its own if that is of any use ? If so, what email address do I send it to ?
      Regards
      Steve
      My Portfolio
        You can send anything that reproduces the crash to vray@chaosgroup.com
          Have this problem too. It is scene depending. I have a rug that renders OK in one scene
          but in other scene it crashes MAX in the end of render proces.
          Jozef
          Jozef
          www.cad-vizualizacie.sk
            Hi Jozef,
            As Vlado said,
            and we will look into it.
            Tashko Zashev | chaos.com
              Jozef
              Very strange. I decided to give hair and fur a miss and go with vray fur where I'm getting fairly good results.
              I do however still have crashes with this scene during pre-pass so will try and zip it all together and send across. Even in max 2013 its happening.
              Regards
              Steve
              My Portfolio
