vray sun and active shade won't update
  • vray sun and active shade won't update
    When I put a daylight system and a vray sun in my scene, the active shade window won't update materials or camera settings. However, it will update the sun position. If I switch back to a dome light with an hdri, it updates just fine. Very strange, any thoughts? Thanks in advance.
    Which 3ds Max version is this?
      We are currently running 2011, thanks.
        What Vray version are you using ?
        We've done some tests with Max 2011 and Vray 2.30.01 - and it work correctly.
        Is this happens on every scene you have - or on a particular one ?
        Is there any difference if you are not using a DayLight System - just Vray Sun ?
        Thanks in advance.
          I apologize, i've been out for a while. for some reason, it has resolved it's self. I was a couple of files, even new ones, but now everything seems to be ok. obviously something I was doing wrong, that is now ok. thanks for the response.
