Periodically one of my slaves renders with the wrong gamma. it's intermediate and rebooting the slave's spawner solves it, but why is it happening? It's an easy fix, but after rendering all night just to see lighter boxes, is painful.
Wrong Gamma
Wrong Gamma
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
try blow away 3ds max prefs dir and see if that helps.Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
stopping/starting the vray spawner worked, and now it's rendering correctly but it shouldn't happen.Originally posted by Morbid Angel View Posttry blow away 3ds max prefs dir and see if that helps.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I get it happening every now and then. I don't know what causes it but it seems to happen when I cancel a render and re-start immediately. It's like the scene has failed to update or be sent over to the slaves for some reason. Annoying! If it's persistent then I just re-start my local copy of max and it seems to work...
It would be good to know why this happens...
Originally posted by Pixelcon View PostI get it happening every now and then. I don't know what causes it but it seems to happen when I cancel a render and re-start immediately. It's like the scene has failed to update or be sent over to the slaves for some reason. Annoying! If it's persistent then I just re-start my local copy of max and it seems to work...
It would be good to know why this happens...Bobby Parker
phone: 2188206812
- Windows 11 Pro
Agreed. I ALWAYS wait around to watch my render kick off before heading home because of this issue but batch renders are another story... I can often spot the problem occurring during the IR pass which either means the IR map calc is the issue, or that we have a separate issue although it does appear like the slave is using the wrong gamma...
yes. that is checked. I can start/stop dozes of times, usually without any issues, but once in awhile I'll get this issue.Originally posted by tashko.zashev View PostDo you use the option "Restart slaves on render end", which should help?Bobby Parker
phone: 2188206812
- Windows 11 Pro
I'm exactly the same as above.
it's happening again, now! How do I reset the irradiance map?Originally posted by tashko.zashev View PostHi,
Can you try to use "Reset" irradiance map button the next time you see this issue instead of restarting the render slave?
And let us know if this solves it.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I am using Brute force and Light cacheBobby Parker
phone: 2188206812
- Windows 11 Pro
but I am not using IrrOriginally posted by tashko.zashev View PostThe "Reset" is next to the Irr Map "Mode" select option where you select - Single frame, Animation prepass ....Bobby Parker
phone: 2188206812
- Windows 11 Pro
