Strip render issue
  • Strip render issue
    Hello,
    just wondering what could be wrong.. when using strip renders I am getting different stripes.. brightness/contrast or gamma differences.
    After the stitching process u can see the stripes.
    Does anybody know what could fix that issue ?
    thank you very much !
    www.bernhardrieder.com
    rieder.bernhard@gmail.com
    Do you use 3DS max Gamma/LUT correction settings ?
    You can check the Gamma settings for the Backburner job (right click on the job and "Edit settings").
    What are the Max and V-Ray versions?
    It's working fine in my test!
    Tashko Zashev | chaos.com
      yes.. I do use the 3dsmax Gamma/LUT correction.
      And when I check the gamma settings for the backburner job it's the same as in the max settings.
      max2011/Vray 2.20.03
        Is it possible to send us a scene file which reproduces the issue (vray@chaosgroup.com), so we can investigate further?
          This can also happen when you have unchecked "check for missing files" in the render dialogue and a slave cant find a map used for environments like a domeligh map or env. map.
          Signing out,
          Christian
