Render to Texture render black frames, VFB OFF
  • Render to Texture render black frames, VFB OFF
    I'm trying to do render-to-texture on a simple box environment but all my outputted maps are rendering black. Vray VFB is off. I can see it rendering in Max's renderer and the mapping looks good, but nothing seems to want to output, no alpha or RGB data. I'm using Vray 2.30.01 and Max 2013 w/ Update 6.
    Bump: confirmed that render-to-texture works in Mental Ray fine, but VRay only outputs black frames for me not even with an alpha. Any ideas??
      Could you please attach a screenshot of your render to texture settings?
      Zdravko Keremidchiev
        Here's a screenshot of my settings...
        http://www.japetusproductions.com/Im...s/settings.jpg
          Use the V-Ray specific bake elements (VRayCompleteMap etc). You will need to scroll down the list of bake elements to see them. The standard ones will not work (for the same reason that the standard render elements don't work with V-Ray).
            Ooooh, I didn't even see those. That makes sense. Thanks Vlado!
