Liquid/Fog Problems
  • Liquid/Fog Problems
    Hey Guys, i have a problem with my fog.I`m working on a Wine bottle. The bottle is clear glass and the wine is a rosè. No matter what i do the liquid turns black when i apply fog.the same way around. make a glass with a fog and then try to put water in it. the liqiud is black.!? do you understand my problem?the geometrie is right i tryed two solutions to imitate liquid in glasses.The problem is fog + fog. maybe you got a one render solution.
    thx
    www.twentyfourpixel.de
    Can you post an example image?
    Do you have overlapping faces between these objects ?
    Tashko Zashev | chaos.com
      No there are no overlapping faces. This is my Scene a Pic1. Bottle green and empty Pic2. Liquid surface detached and normals flipped. Pic3 only the water.Click image for larger version
ID:	846846Click image for larger version
Name:	with water.jpg
ID:	846847Click image for larger version
        can you post a scene? are your measurements set correctly? i tend to like the liquid to overlap the bottle slightly in cases like this. maybe your fog strength is too high?
          Hey da elf, yes i work in cm and the scale is 100%.even if my fog multiplier is down to 0,1 it turns black....i tried out with overlapping & detached and flipped normals. i`ll upload the scene but now its 22:27 o clock in germany and the scene is at work. thank you
            So here is the scene. maybe some one of you guys can help me..?thx
            http://danielyaqub.bplaced.net/filem.../Oilbottle.zip
              Thank you for the scene.
              The Fog multiplier color value for object "oelflasche" is too high "5", try to set "0,1" for an example.
              Also "Secondary rays bias" parameter can be lowered too.
                Ok but i dont get a nice colored glass if i make the multiplier down to 0,1 and when i turn down the fog bias it will be the same , or not? do you have found a solution?please let me know or post a image. thx
                  Hi again,
                  I made some changes to the V-Ray settings, bottle/wain materials and bottle geometry.
                  HDR Environment is replaced with simple white color (the file is missing).
                  "Secondary ray bias" option is set to "0" ("0.1" is too high).
                  Both objects, bottle and liquid has fog color applied.
                  An example render with the original bottle and the new one:
                  Scene file:
                  Oilbottle_Edit.zip
                    hey tashko, 1000 thx. i`ll check the scene to look what u have done and will write you. thx a lot
                    hey tashko, awesome!!so the only thing you`ve done ist overlapp the geometrie that size?and cant i just flip the normals?Thx so much
                      You cant use flip normals. For fog to work object need a volume, closed space. This is what you didnt have in your bottle model.
                      AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
                      2D | 3D | web | video
                      jiri.matys@gmail.com
                      https://gumroad.com/jirimatys
                      https://www.artstation.com/jiri_matys
                      https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
                      https://www.instagram.com/jiri.matys_cgi/
                      https://www.behance.net/Jiri_Matys
                      https://cz.linkedin.com/in/jiří-matys-195a41a0
                        Exactly, also need to play with Fog value because it depends on the object thickness.
                        And if you need to increase "Secondary ray bias" i can advise you to use values around "0.001"
                          thanks a lot tashko & jiri! i didnt know that fog needs a volume like that. u saved my work! thank you for solving other peoples problems, thats what i love in this community!
