fur looks different ADV/RT
  • fur looks different ADV/RT
    hello there.
    i get some quite different result here...
    is there some used-look-switch i dont know?
    Hmm can you give steps for reproducing ? Or maybe a scene ?
    Peter Matanov
    Chaos
      there is nothing special in this scene. just a circle with fur and a length-map for fur.
      without length-map i have also different result.
        I couldn't reproduce it either.
        We know that it is simple scene - but it would be much easier for us if you attach it.
        Also please inform us about the exact versions of 3DSMax and Vray.
        Thank you very much in advance.
          i use MAX 2013, SP6; Vray 2.40.04
          example.zip
            Ahm I see the difference and will notify you in this thread about the progress of the investigation
            Peter Matanov
            Chaos
              The problem is that you scaled your source object (the circle). This is a known issue - vrayfur+scaled geometry (and I hope it will be fixed soon). Please use non scaled objects for sources
              Peter Matanov
              Chaos
                ha ha ha! and i started already to get mad to myself, cause i wasnt able to reproduce this again.
                the matrix got me
