DR not picking up node
  • DR not picking up node
    So I am rendering a large image and one of my nodes happens to have lost the drives that are mapped on the network - So I've gone into the node and added all the relevant drives and everything is fine on that end...
    My understanding was that VRay will add nodes even mid-render, but this one doesn't seem to be being added at all. Do I have to stop the render and start it again, or is there something else going on here?
    Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
    www.robertslimbrick.com
    Cache nothing. Brute force everything.
    It happen to me few times that Vray pick up extra node as it become available but its not 100%.... u usually have to restart render. Maybe it just takes a while to pick up node?
    Thanks, bye.
      V-Ray will count the render nodes at the beginning of the render process and will return a number with those that are being connected and ready. So for the current frame only this number of nodes will be used. If you run a spawner on more machines (during the render process) and they are already added in DR list, V-Ray will try to connect them for the next frame (or render).
      I'm not sure whether the issue with lost mapped drives is V-Ray connected, but can you post the error messages (if there are any) in the V-Ray log from the workstation and problematic render node?
      Tashko Zashev | chaos.com
