Can not change VRay license server information
  • Can not change VRay license server information
    I am trying to install the latest version of Vray for 3DS Max 2013. I had previously run a computer as a render slave but now will be using it as the server. When I attempt to change the Vray license server information from the original server IP address back to localhost I get an error that the settings could not be saved.
Name:	vray server error.jpg
    I have attempted to uninstall Vray and re-install it, I have attempted with the vrlserver turned on, with it turned off. I can’t think of what would stop me from making this change. Is there a way to make this happen? I don’t know if I need to some how clear the registry or if there is a program running in the background that is preventing this. Any help or insight would be greatly appreciated!
    Thanks!
    Also when I attempt to "Remove VRay License Server" nothing happens.
      Right-click on any of these options and select "Run as Administrator..." and it will be fine.
        Vlado,
        Thank you! It took you 15 seconds to solve a problem after I pounded my head against the desk for a couple hours...my old computer always ran things as Admin. thanks again!!
