Normal Map issue
  • Normal Map issue
    Has anyone had this issue before, the problem might not even be Vray but shows up strongly on SkinSSS2 shader.Click image for larger version
    Nathan Evans
    nate@arcfx.com
    www.arcfx.com
    I found it's coming from the refraction and specular layer, btw.
    Nathan Evans
    nate@arcfx.com
    www.arcfx.com
      Can you post that scene along with the normal map?
      What software did you use to generate normal map ?
      What Vray/Max version are you using ?
