fade objects
  • fade objects
    i've always faded things in and out in post, but this time this is really inconvenient. is it me, or is there still a lot of issues doing this in render?
    keyed visibility track, refraction and opacity all produce flickery results, which also seems to escalate with backburner.
    anyone know some setting or material trick i could try to make this work better?
    Do you mean distance fade out effect to be achieved ?
    Tashko Zashev | chaos.com
      no, just a simple keyed opacity for instance, that goes from fully visible to invisible over 25 frames
        Ah, yes.
        Increasing the "Max transp. levels" parameter should avoid any artifacts in this situation. Don't know how complicated are your objects but probably 50 is not enough.
        Let me know if this helps.
          aha, "Max transp. levels", sounds good, thanks Tashko. i upped it to 1000 and ran a render, i will let you know how it goes tomorrow
            and it works like a charm now, good to know, thanks Tashko!
              I'm glad to hear that, many thanks for the update.
                Useful tip... will try to remember this one.
                Alex York
                Founder of Atelier York - Bespoke Architectural Visualisation
                www.atelieryork.co.uk
