3ds max issuse(v-ray)
  • 3ds max issuse(v-ray)
    I have used models from different file......
    And there were plugins used in those file which I do not use....
    but each time I open my file I get error of missing *.dll
    how do I get rid of it.
    This is what happens when I do DR rendering
    Thanks regards savio
    Well this is a max issue, if it can be called as a issue.
    When you decide to use additional plugins be sure to install them on all DR nodes to work properly.
    In your case you have a modifier plugin EdgeChEx that chamfers the edges of a geometry, if you don't need it in stack you can collapse the mesh and will work just fine.
    Or find on scriptspot any related scripts that can find the missings, they should be free.
      thanks slazzo
