3dsMax State Sets and VRayRenderElements
  • 3dsMax State Sets and VRayRenderElements
    A different RenderElement set for every State set of 3dsMax cannot be created.
    The following errors are displayed.
    1 states have encountered errors and have been disabled to allow you to continue working. Please report this to Autodesk by sending us the following text:
    State type: Autodesk.Max.StateSets.Entities.StateSets.Renderin g.RenderElement+Parameter
    Error: System.Runtime.InteropServices.SEHException (0x80004005): External component has thrown an exception.
    at Autodesk.Max.Wrappers.Value.get_ToBool()
    at Autodesk.Max.StateSets.Entities.StateSets.Renderin g.RenderElement.Parameter.get_FileName()
    at Autodesk.Max.StateSets.Entities.StateSets.Renderin g.RenderElement.Parameter.GetParameterValue(Proper ties property)
    at Autodesk.Max.StateSets.Entities.StateSets.Paramete r`1.EndRecording()
    at Autodesk.Max.StateSets.Entities.StateSets.State.En dRecording(IState state)
    It is not supporting?
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    As the message itself says, please report this to Autodesk.
      ok.
      It is the support hoped from the autodesk side.
      Thank you.
      oakcorp.net
      v-ray.jp
