Hair and Fur not rendering animation in mr prim mode
  • Hair and Fur not rendering animation in mr prim mode
    Hi all
    In max 2014 and VRay 2.4 I've made a plain and slapped a Hair and Fur on top of it and used the "Tall Straw (breeze)" preset.
    Added vraysun,sky,cam
    In effects I've set it to "mr prim" mode.
    If I scrub the timeslider I can see the animation of the grass in the viewport, but when I render, it renders each frame the same, NO ANIMATION!
    If I switch to scanline and try "buffer" and also "geometry" mode, the grass animation renders fine.
    So whats up? I'm sure this use to work before?!?
    Kind Regards,
    Morne
    Same here , thanks for reporting !
    Peter Matanov
    Chaos
      Any more news on this yet?
      I mean did you guys manage to determine if it's a max thing or a vray thing?
      Any alternatives I can do in the meantime? Like maybe use max frame buffer instead of VFB and render with buffer mode?
      Any other suggestions?
      Kind Regards,
      Morne
        Originally posted by Morne View Post
        Any more news on this yet? I mean did you guys manage to determine if it's a max thing or a vray thing?
        On the V-Ray side, we pass exactly the same data as in 3ds Max 2013, where things work fine. I don't know what's changed in 3ds Max 2014; other types of hair animation (like dynamics) seem to work fine.
        You can certainly do that, but it will be a pain.
        You can go back to 3ds Max 2013 which works fine. Or perhaps use another hair solution, but that might be out of the question.
          So where do we go from here to make it work in 2014 the way it should?
          Kind Regards,
          Morne
            I'll bring the question up on the ADN and also with Joe Alter, but unfortunately I don't know how long it will take to resolve it.
              OK Thanks Vlado, please keep us posted on the status of this important issue...
              Kind Regards,
              Morne
                Any news on this yet?
                Kind Regards,
                Morne
                  Anything? a reference number or tracking number or anything from ADN?
                  Kind Regards,
                  Morne
                    I don't have any news for you yet. The Hair&Fur SDK is not officially supported by Autodesk, so I guess this may not be a priority.
                      Ahhhhh nuts
                      ok thanks...
                      Kind Regards,
                      Morne
                        No news on this? Such a pain to have found this out now.
                        Michael Wentworth-Bell
                        Motion Graphics Artist
                        Melbourne, Australia
                        My site - Digital Lode
                          It seems that there is nothing that we can do about it on our end - we simply do not get the animated data from Shave in 3ds Max 2014 for this particular type of hair animation (other types like dynamics work fine). Autodesk were not sure what's changed since 2013 either...
                            Thanks for the quick update Vlado! I submitted a bug report to Autodeksk, I guess it will have been sent to them a few times by other users by now (hopefully).
                            It seems they're not interested in fixing this issue, which is a real shame. If it's not working in 2014, I can guess it wont work in 2015 and beyond. That Hair and fur grass trick is actually a really handy (and free!) quick and dirty grass solution...
                            Having to move a project back to a previous version is really dicey and time consuming.
                            Thanks again, hoping some for some good news from ADSK in the future...
                            PS: As a side note....any chance of Vray Fur getting some more features? The ability to have random 'noise' movement on each hair strand (just like the animated frizz option that is in Hair and fur) would be awesome. I found that that simple frizz animation (using a noise map) was way simpler to set up than trying to get the same result with space warps...but space warps/collisions support would be awesome too!
                            • #15
                              I hope this "magically" starts working again max 2015...
                              Kind Regards,
                              Morne
