Net render uses wrong gamma
  • Net render uses wrong gamma
    I have a scene that was rendering fine both locally and on the network (Using ButterFlyNtRender, which uses 3dsmaxcmd.exe).
    Then I imported a stock 3d model that had been created with VRay 1.5 (I am on the latest 2,x build). I got the warning about should Max turn off the gamma settings because this scene was created without them, and I chose not to modify the gamma.
    In Max everything looks fine. It renders fine, etc. When I go to net render the scene comes out too light, like it is rendered without the gamma correction.
    Any thoughts on how to fix this? I checked the gamma settings under preferences and they were set to gamma 2.2.
    Note I had a scene that was fine, was gamma 2.2 linear workflow. Then I imported a object (series of objects from one file) using Merge. Now the issue, but only when net rendering. I checked the paths, and they are OK.
    Thanks.
    I finally got it to work right. Being under deadline I did not take the time to narrow it down scientifically (i.e. I changed a bunch of stuff at once). However, I think perhaps it was the turning the gamma corection off and back on in the prefs that did it???
      I'm not really sure what causes this, but it has come up occasionally before. Glad you sorted it out
        Thanks for the reply, Vlado.
        When you saw the problem before was it only after importing older geometry (from an older version of vRay), like a stock model?
        Thanks.
          I have this happening again for myself - seems to happen when I switch between baking the gamma or going linear. I haven't had any issues for the longest time while being in 'color mapping and gamma' mode - but today I switched the project to 'none' and it looks like the DR nodes don't pick up on this... at least not in the precalc buckets - but it seems to be rendering fine...
          Brendan Coyle | www.brendancoyle.com
            The precalc buckets might be a bit off in general...
              The issue has come back. I am not sure why, though. I think I re-merged another copy of a stock object (that I modified outside my main scene).
              Any thoughts on fixing this? Going and turning the gamma correction off and on does not seem to have worked.
                Somehow I got it fixed again. Always a pain when you are trying to figure this stuff out on a deadline, because you don;t have the time to take a scientific approach to problem solving. YOu have to take a shotgun approach to get things fixed as quickly as possible...
                I *think* turning off gamma correction in the pref, saving the file. Restarting Max, loading the file, turn ON gamma correction in the prefs is what fixed it.
                  Thanks for the feedback - let us know if the issue appears again.
