I am trying to map several bitmaps, on one object, and I am using a composite. I have 4 decals, and I am assigning map channels, and UVW mapping. But, the UVW map doesn't seem to work. I want to move the labels around via the gizmo, but nothing. HELP!
Map Channels
Map Channels
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
Are you adjusting the corresponding uvw for that specific channel? If you have multiple uvw's in the stack you might have to turn off the end result to see what you are doing.Brendan Coyle | www.brendancoyle.com
yes, I am doing all of that.Bobby Parker
phone: 2188206812
- Windows 11 Pro
it's acting wonky. I can use RT to see things, but the MAX VP isn't working at all.Bobby Parker
phone: 2188206812
- Windows 11 Pro
If I make the logo, in the composite stack visible, it works. But, I can't see them in relationship to each other. I amnot sure how someone is supposed to line up things. Ugh!!!! Am I doing something wrong, or is this how it works?Bobby Parker
phone: 2188206812
- Windows 11 Pro
I will try it, thx.Bobby Parker
phone: 2188206812
- Windows 11 Pro
