texture warning
  • texture warning
    warning: Texture "Map #7731" returned an invalid bump normal (XYZ -1.#IND,-1.#IND,-1.#IND).
    Any clues as to what this means? It's appearing during the lightcache calculations and I wonder if it's affecting the speed of the render. The warning has popped up 8 times in a row already.
    canceled and got another warning
    warning: Material returned overbright or invalid color (object "Rectangle022",RGB:-1.#IND,-1.#IND,-1.#IND)
    going to investigate this object...
    Brendan Coyle | www.brendancoyle.com
    Both issues were connected to the same material, which had a .jpg texture in the diffuse that was a white paint swatch (248,248,24. Map #7731 is the bump map on that material which is a grungy black & white .jpg texture.
    Re-rendering.
      It's good to fix those warnings; they do slow down the render a bit.
