Baking map render black
  • Baking map render black
    Hello,
    Just to make sure there is no mistake here:
    Element Name -> Target Map Slot
    DiffuseMap -> Diffuse map
    SpecularMap -> Reflect map
    NormalMap-> Bump map
    VrayMtlReflectHilightGlossiness-> Refl. gloss
    What about VrayCompleteMap?
    I can see the render in the VFB and Max buffer, but nothing appear in the renderToTexture map.I have just the RayMtlReflectHilightGlossiness that get out, all other one render black!!!
    For the test, the render have been setup to LC/LC, and map size 256x256
    I'm not familliar with renderTotexture, so I probably do something wrong here.
    Could be a bug on Vray 3.x?
    Thanks
    Can you post a scene or send it to vray@chaosgroup.com?
      Only pick the Elements that have VRay at the beginning of them:
      VRayDiffuseFilterMap -> Diffuse map
      VRayMtlReflectGlossiness (?) -> Reflect map
      VRayNormalsMap-> Bump map
      etc.
      Brendan Coyle | www.brendancoyle.com
        Thanks,
        Is multitexture plugin supported by rendertotexture?
          Yes - it is supported.
          Let us know if you have any troubles with it.
            Hello again,
            We would like to inform you that baking geometries with overlapping surfaces could crash Max because of memory leaks.
            In the scene you sent us there are more than 1500 overlapping surfaces and they are the reason for the crash - this is already know issue and we already have in into our system but it is not fixed yet.
            We will let you know when we have some news about this bug.
