VRay proxy mesh - re-link to Max
  • VRay proxy mesh - re-link to Max
    I've never used VRay proxy objects and have been given a file that should link to lot's of them, how do I re-link from my Max file to the proxy objects?
    Many thanks in advance for any help.
    Collective.
    Not sure if I understand you correctly - you have a file with a proxy objects but the path to this objects is changed ?
    If this is the case you can use Assets Tracking window and under External Link row you can see all VrayProxy objects attached to the scene.
    Select all of them right click and choose Set Path option - then you could point out to the correct location.
      If you set up the proper 3ds Max assets paths, then 3ds Max will link them automatically. Or if you dump the .vrmesh files in the some folder as the .max file, it will find them too.
