Prepass with BF?
    Originally posted by Morne View Post
    I just get
    "OK"
    in the listener
    Ok, in that case there aren't any materials using interpolation in your scene.
    and the maxscript window just changes the code into pretty colours
    You can execute single lines of code in the listener but for multiple lines you need to use the maxscript window.
    Dan Brew
      Would it be possible to send the scene for investigation ?
        no sorry this is one of "those" projects which is hush hush for now
        Kind Regards,
        Morne
          Originally posted by DanielBrew View Post
          I use this for find all materials using interpolation. It also prints the names of guilty materials and the objects to which it is applied in the listener.
          Code:
              clearListener()
              for m in getClassInstances vrayMtl processAllAmins:true do
                  if m.reflection_useInterpolation == true do
                      format "Material:% Applied to:%\n" m.name (refs.dependentNodes m)
                      m.reflection_useInterpolation = false
                  if m.refraction_useInterpolation == true do
                      m.refraction_useInterpolation = false
          Dan, thanks this is soooo helpful!
            You're welcome. VMC will turn all interpolation off but sometimes it's useful for know which materials/objects were using them to stop it happening again.
            Dan Brew
            • #21
              V-Ray prints all such materials in the V-Ray log file too.
