Bucket noises when using Vray Environment Fog
  • Bucket noises when using Vray Environment Fog
    When using VrayEnvironmentFog we witnessed strange artifacts which show bucket areas.
    It's not the GI as far as I can see it ... And we are not within the gizmos for the fog even ...
    Best, Peter,
    xoio
    Edit: I just tried in progressive mode, it's still there ...
    Is there some kind of geometry there? Are you using a gizmo for the fog?
      Yes, I use a HiPoly-Ball, which is modelled to simulate some Cloudshape ... and a noise-fractal in the density to break up the cloudshape. The Geometry is set to not renderable in the properties ...
      The scene is fairly small, if you want I can send it over ... ?
      Cheers, Peter
      Edit: Attached Screenshot:
        Yes please - send the scene either to support@chaosgroup.com or attach it here in the forums.
        Thank you very much in advance.
