Vray Lens Effects seems to delete G & B channels from final render
  • Vray Lens Effects seems to delete G & B channels from final render
    So, Vray Lens Effects seems to work fine when rendering locally with DR.
    But whenever I send to Backburner with DR, the render begins fine, beauty pass renders fine, but when applying Vray Lens Effects at the end it deletes the Green and Blue channels leaving me with just a red image!
    Pretty much left the Lens Effects at their default, and Ive only noticed this when rendering 'hi res' (in this case 4000 x 2250)
    Bit behind the times on Vray 2.3
    do you experience the same problem with lower resolutions? Can you send us a scene?
    Regards,
    Asen
      So far not with lower resolutions, but I havent tested lower res over backburner. So it could be a backburner thing.
      I'll look into getting a smaller scene together.
        If you manage to reproduce the issue with low resolution/quality settings will very helpful.
        However, In case that it is reproducible only with the production setup, please send us the scene file along with all textures to our support mail. We will try to replicate the issue with V-ray 2.3 build or the latest one.
        Please include the exact OS and software configuration that you are using on all render nodes.
        Tashko Zashev | chaos.com
          Cool, Im testing lower res this eve.
            Emailed to support@chaosgroup
