Reflection Issues
  • Reflection Issues
    Hi
    I hope someone can help with this issue, The floor has two marble finishes. The lighter is a floor generator with a multi texture applied, no UVW map. The second darker marble is standard edit poly with UVW map applied. As you can see the reflections are completely different angles.
    Is there a fix for this situation ?
    SteveClick image for larger version
Name:	reflect issue.jpg
    in the reflection slot a falloff with activated fresnel overwrite in one material?
      hi...I have this happen sometimes. It might be good to try...
      -to reset xform
      -clear smoothing groups of all polys for the dark tiles (assuming those are the incorrect reflections.)
      Sorry if this was already tried...It happened to me sometimes when I get a model from a client either revit or sketchup. Glass always does that until I do the above steps.
      HTH
        Thanks for the replies Guys, I will try both ways when the render has stopped.
          Let us know if you still have this issue afterwards.
