Light Buckets
  • Light Buckets
    I am battling the light bucket problem again. I rebooted everything, but still, it persists! has there ever been resolution to this? I haven't seen this is months, but all of a sudden, it's back. Nothing has changed on my machines, except for a video card, but I rendered successfully already using it.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    you should know by now that you need to give more information.
    what is the material, is it dr, are you using saved IRmaps, does it happen when you switch maps off, does it happen when you switch gi off etc. what does it look like in the channels (raw diffuse, ref, gi, lighting etc) - see if it's only happening in one.
      I am using DR, but I don't use saved IRmaps. All the channels are showing the same issue. It's not always the same machine either. I can let the render finish, start it again, and another one does it. I'll see what happens when I turn GI off.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Are you rendering with color mapping enabled? It's a bit odd that it's cropping up now after having been running error free... I'd slowly strip the file down and see if you can find the culprit if the problem is only happening with this project
        Brendan Coyle | www.brendancoyle.com
          same thing with GI off, but with a material override, it's fine. Now, what could cause that? it's obviously rendering the material; it's just rendering lighter.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            odd... it was a double sided material on my grass.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Do you have the same Max service packs installed on all your nodes?
              See this thread: http://forums.chaosgroup.com/showthr...n-rendering-BB
              Dan Brew
                I am pretty sure I have the same SP, but I'll double check. And, like I said, I have rendered a dozen successful scenes. i removed the double sided material, and all is good.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Is the issue related to the scene ?
                  If yes - would it be possible to send us that scene along with all the external assets ?
                  Have you got Check For Missing Maps option enabled from System Rollout ?
                    it was a double sided material that caused it.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Thanks for the information - would it be possible to send us simplified version of the scene including all needed external assets for investigation ?
                      Let us also know what Vray/Max versions are you using and make sure that the same Vray version is installed on all machines.
                      Thank you very much in advance.
