Vray and Vector Maps
  • Vray and Vector Maps
    Has anyone else seen an incredibly noticeable slowdown when calculating light maps and using vector maps in Max 2014? The slow down occurs during LC+Imap, then renders fine in view except when it has to be calculated in reflections/refractions. Does this have to do with how vector maps and their resolutions are handled in Max 2014?
    I would assume so. The vector map works by rasterizing the file into bitmap tiles. There is also probably some memory cache to hold already rasterized tiles - perhaps there is an option to control this and give it more RAM?
      Thanks for the quick reply Vlado. Would you recommend not using vector maps then?
        You should be fine with any maps that are "optimized" to a certain degree. There will be some hiccups and the occasional stuttering during rendering, but they seem to work fine for the most part here. The filtering/mip-maps are more of a concern IMHO (evident when viewing the maps at a glancing angle, or with an animated camera zooming in/out).
        There is a memory/cache control, but I have yet to figure out if it actually does anything. I have changed it from minimum to maximum without it noticeably affecting render time or the hiccups.
        Signing out,
        Christian
