I am trying to get HQPlants (on a network drive) working with ForestPro 4.1.5 but my DR render slaves don't seem to be able to get any of the textures.
Itoo recommend adding the maps path to the 3dsmax.ini file of the slaves, which I have done, but every time I set DR render the 3dsmax.ini is over written without the custom map paths I just added.
The DRspawner.log seems a bit odd and I was wondering if this was causing the 3dsmax.ini overwrite?
0: [2014/Jan/15|16:28:41] ========================== Starting new session ==========================
1: [2014/Jan/15|16:28:41] Got this module name: C:\Program Files\Autodesk\3ds Max Design 2014\vrayspawner2013.exe
2: [2014/Jan/15|16:28:41] Got this INI file name: C:\Program Files\Autodesk\3ds Max Design 2014\VRaySpawner.ini
3: [2014/Jan/15|16:28:41] *** ALERT! Could not open INI file: "C:\Program Files\Autodesk\3ds Max Design 2014\VRaySpawner.ini". Using defaults.
4: [2014/Jan/15|16:28:41] --
5: [2014/Jan/15|16:28:41] Dumping current settings...
6: [2014/Jan/15|16:28:41] VRaySpawner temp dir: "C:\Users\Simon\AppData\Local\Temp"
7: [2014/Jan/15|16:28:41] Application name (MAX/VIZ): "C:\Program Files\Autodesk\3ds Max Design 2014\3dsmax.exe"
8: [2014/Jan/15|16:28:41] --
9: [2014/Jan/15|16:28:41] Process id is 2996 (0xbb4)
10: [2014/Jan/15|16:28:41] Executing ""C:\Program Files\Autodesk\3ds Max Design 2014\3dsmax.exe" -server C:\Users\Simon\AppData\Local\Temp\vraydummy2013.ma x "
11: [2014/Jan/15|16:33:59] Process id is 2996 (0xbb4)
12: [2014/Jan/15|16:33:59] Executing ""C:\Program Files\Autodesk\3ds Max Design 2014\3dsmax.exe" -server C:\Users\Simon\AppData\Local\Temp\vraydummy2013.ma x "
The 3dsmax.ini file of the DRslaves I'm trying to modify are located here: C:\Users\username\AppData\Local\Autodesk\3dsMaxDes ign\2014 - 64bit\ENU
thanks
thanks
