Has anyone one had this issue
I have a room lit by a skylight. I have vray lights in the windows set to portal.
I can render the room with irradiance map and light cache image attached.
If I switch to PRI. brute force, SEC. brute force the image comes out much darker.
Can anyone help me understand what might cause this?
Also can anyone suggest which method would be the fastest
For 500 frames the camera tracks across the room. The curtains in the nearest window are blown in the breeze.
I was planing to use the IRmap and light cache, hide the curtains, bake the light, then render with brute force on the curtain material.
Settings for the IRmap multi Incremental min.-3, max.0. subD.200, sample.30 Lightcach flythrough subD 3000. this was taking 2 hours on a 24 core 3 ghz machine for the light pass. Ouch!
This prompted me the look at brute force. DMC setting - global subdivisions multiplier 0.001 noise threshold to 0.005 adaptive dmc - min 1 max 30. This is when I ran into the light differance issue. The render looked about 6 stops darker.
