Use of Normal Maps in Vray
  • Use of Normal Maps in Vray
    Hello!
    I have been searching but cannot find much information on this topic.
    What is the proper procedure for using Normal Map images with Vray? My understanding is that you place a "VrayNormalMap" in the Bump slot, and then the desired map within. However the results i have been getting are not at all desirable and I get much better results with a simple black and white map in the bump slot. (see the attached images, The one rendered with normal maps has errors and in general behaves strangely)
    I feel that either I am doing something incorrectly or that there is some kind of bug with normal maps.
    any help would be much appreciated.
    Thank you!Click image for larger version
Name:	Bump Slot with Black and white map.jpg
ID:	879509Click image for larger version
Name:	Vray Normal Map With appropriate Normal Map.jpg
    make sure gamma is set to override 1 where you pick the bitmap. normal maps are very picky about gamma.
      That was it! Thank you so much!
        Also make sure the bump value is set to 100%. (That's a max thing, not sure if vraynormal ignores it.)
