DR rendering problem?
  • DR rendering problem?
    Hi, attached herewith a jpeg image which show the weird bucket color when calculation irradiance map with DR, but the final render is fine,
    is this a bug or error?
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    It is the render nodes returning buckets with different gamma.
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      Thank you for your reply, i wonder why the final result look fine even it has difference gamma??
      how to avoid it?
      Regards,
      Jackie
      Jackie Teh
        As far as I know you can't avoid it.
        Chris Jackson
        Shiftmedia
          Vlado ones mentioned its just the preview doing it and if you're beauty is fine, you can just ignore it
          (would still be nice if they can "fix" it however)
          Kind Regards,
          Morne
            To expand on the other comments, this is as far as I have understood, the DR slaves buckets visible representation being compressed to save network bandwidth.
            The issue here being that they look like faulty buckets making us paranoid and stressed.
            Hopefully Chaos/Vlado will ease up on the compression so they don't look quite as bad in some future version, unless it has already been fixed in v.3.x.
            Signing out,
            Christian
              Second this.
              Alex York
              Founder of Atelier York - Bespoke Architectural Visualisation
              www.atelieryork.co.uk
