Strange (minor) Problem with DR Vray 2.4
  • Strange (minor) Problem with DR Vray 2.4
    We´re currently testing Refamo, an awesome software to monitor your renderfarm btw. and we just
    experienced something strange. We´re rendering a quite large image (without the Vray Framebuffer i must add).
    As further you zoom out the frame buffer, as less CPU the render slaves will use.
    Attached are 3 images. The first is a screenshot when the Framebuffer is zoomed to 1:16
    The second is when it´s zoomed to 1:8 and the third is a zoom level of 1:2.
    The CPU usage will stay that way until you zoom to another level.
    Usually we do use the Vray framebuffer and this is the first time we noticed this behaviour.
    I will make some tests if this happens with the Vray Framebuffer, too.
    Make sure the 3ds Max Bitmap pager is disabled and see if that helps.
