Hi I've tested with the new Clipper object - which is by the way a great feature - but i guess its just an early implementation and not meant for complex cuts.
I was trying to set a cut with 2 clipper objects.
the result showed that the first clipper in red had the desired effect. the second clipper (green) in another direction worked too, but also showed the resulting clipping fillings in the already disappeared parts from the first clipper.
I guess its not meant to use more that 2 clipper at once - but i'd like to know if in future there would be options to use free form clipper objects.
