Missing reflection from glass doors
  • Missing reflection from glass doors
    There are two glass doors. The one on the left has a good reflection. The one on the right is using the same material, but has no reflection!?
    I've tried flipping the glass object over, and most recently, cloned the one on left and moved it to the right. Still nothing. They are totally parallel with each other. This seems really strange!?
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    it's going to be a normals problem i can almost guarantee it. If you're cloning it it might be getting flipped, and if you're trying to flip the normals in edit mesh mode then they will likely be ignored. best to just create a fresh box and be done with it.
    Alex York
    Founder of Atelier York - Bespoke Architectural Visualisation
    www.atelieryork.co.uk
      I just realized that the glass material has a falloff parameter (set at 100) on the reflection map, and is set to "fresnel". Could this be an issue?
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        Good advice. I'll give that a shot and let you know. Thanks!
        David Anderson
        Software:
        Windows 10 Pro
        Hardware:
        Puget Systems
        TRX40 EATX
        128GB RAM
          Turns out that it's a falloff shader issue in the Relections map. I had it set to fresnel. I changed it to parallel/perpendicular and that seems to have fixed it.
          Thanks.
          David Anderson
          Software:
          Windows 10 Pro
          Hardware:
          Puget Systems
          TRX40 EATX
          128GB RAM
            Thanks.
            That dount sound like proper fix... U should be able to use Fresnel. Can you try not using fresnell texture and just use fresnell tick in vray mtl?
