VrayCarPaintMtl - Unable to control base traced specular subdivs
  • VrayCarPaintMtl - Unable to control base traced specular subdivs
    Is there any way to control the noise in the specular component of a vraycarmaterial. Adjusting the subdivs in the material doesn't affect the noise in my specular, and I'd rather not have to push my dmc settings much harder to get rid of the noise.
    I assume the light subdivs aren't a consideration?
    I inherited this scene, so I'm in a world of w(hy)tf-is-it-setup-like-this
    It seems odd that the car-paint base 'specular' has a trace option, without any control over the traced reflection subdivs.
    Or, what is more likely, am I misunderstanding the shader altogether!
    Any advice appreciated.
    Tested under vray 2 and 3.
    Many Thanks
    Patrick
    First you have to find where the noise comes from. To do that please add Reflection and Specular render elements. Then if the noise is apparent in the reflections > increase the Subdivisions parameter (Carpaint/Options section). To reduce the noise in the Specular one you may need to increase the Subdiv. of your lights.
    Hope this helps.
    Tashko Zashev | chaos.com
