V-ray 3.00.03 crash
  • V-ray 3.00.03 crash
    Hello
    I have a huge problem that is delaying deliveries to my customers.
    Once released the render makes 3dmax crash and fall.
    It happens at random and constant mind. Max sends a report that there are problems with the UI and reset it.
    I do the reset but the continued failure.
    This happens only with V-ray rendering.
    3dmax Design 2014
    Windows 8.1
    Dual xeon 8 cores per CPU
    64 Giga Ram
    SSD hard drive
    Quadro K5000
    Vray 3.00.03
    Would it be possible to send me the scene to vlado@chaosgroup.com ? Or else, send me the file 3dsmax_crash.dmp from your temp folder (type %temp% in Windows explorer) right after the crash? If I can reproduce this, I will be able to fix it as soon as possible.
      Yes
      not know what happened but can not find the file.
      Maybe that is to be removed beyond TEMP
      If it happens again, it keepeth away. At the moment is stable, once the UI interface resets
        Ok ...
        Vlado, I solved the problem and had nothing to do with V-ray in full. It was the Interfas of 3dmax + the Soulburn script, these buttons as they were in 3dmax 2014.
        This caused crash during render.
        After resetting the UI erasing all traces, this instability was resolved.
        all ways, grateful to your prompt response and help.
          Oh ok. Thanks for the update!
            Hello again.
            Vlado has emerged herror again. This time squeezed and render this colapasa and pulls me out.
            I leave attached the 3d max temp.
            Max 2014
            Vray 2.40.XX
              Originally posted by AndresAhumada View Post
              I leave attached the 3d max temp. Max 2014 Vray 2.40.XX
              Where did you attach this?
                Nevermind, I got it. The crash itself is in the RailClone plugin, I don't know if this helps. Is there a way to collapse it to a regular mesh?
                  I forwarded your crash dump to Itoo, I hope that they can shed more light on what's going on.
                    Sorry in your Email by aahumada@instore.cl
