Hyperthreading don´t work with Vray?....
  • Hyperthreading don´t work with Vray?....
    I wanted to know if someone else happens.
    If I render with HT enabled, my render times are worse than if you do not use.
    Must be configured in some special way for HT use Vray?
    In Cinebench the HT is working properly and give some extra performance.
    Attach scene in case anyone want to try it
    Workstation are HP Z820 dual E5-2690 V2 and vray 3.00.03
Name:	test vray z820.jpg
    www.oscarlorenzo.com
    Turn off the 3ds Max Bitmap pager and try again. V-Ray does print a warning about that, if anyone cares to read it...
    Note that you need to save and reload the scene for the Bitmap Pager settings to take effect.
      It works !!!!
      Thanks Vlado
Name:	test vray z820_ok.jpg
