Hello
I have a little an issue with motion blur quality in vray 3.0 using the physical camera.
1) i can't find the "subdivisions" setting. the are not (as suggested by the help file) in the vray camera rendering settigns, nor in the camera settings itself.
2) the quality is controlled by the image sampler - which is stated in the help file and seems to be so, but I have to setup an insane min shading rate (like 3645) and still having some grain in the motion blur.
the case is I'm rendering light trails... fast moving star-like object
rendering isn't that slow at all per frame (2.43 min) but as I have to add more complex and textured geometry into the scene, it may skyrocket that. I guess.
so how can I improve the quality without killing the rendertimes?
EDIT: @shader:
its a vray light shader with a ramp texture in color. no lights at all in the scene yet, but will be required later on. the intensity is at 10 yet. rising the intensity to 60 kicks the rendertime to 7:51 min. not good. the effect is much better though.
an example:
thank you very much in advance.
EDIT: @shader:
an example:
