VRay 3 - VRayPhysCam Guess Vertical Tilt not in Undo History
  • VRay 3 - VRayPhysCam Guess Vertical Tilt not in Undo History
    Just a minor one - when you use Guess Vertical Tilt on a physicalcam, it won't "undo".
    steps:
    1) create physicalcam
    2) shift target up in Z
    3) select cam again and hit guess vertical tilt
    4) press undo (nothing happens)
    5) press undo (target goes back down)
    What you'll see is that if you take 2 Undo steps back, the target will drop down as it should but the tilt will still be applied.
    Alex York
    Founder of Atelier York - Bespoke Architectural Visualisation
    www.atelieryork.co.uk
    Thanks for the pointer; will fix it.
      Good stuff thanks
      Alex York
