Vray 3 DR rendering not responsive with Backburner
  • Vray 3 DR rendering not responsive with Backburner
    I've tried to search for this particular issue but to no avail.
    my setup:
    Vray 3.00.04 with nodes and licences available
    3Ds Max 2012 product update 12
    Backburner 2014
    Created a brand new scene with basic metallic balls to test with. But happens with multiple files.
    Rendering locally from my workstation (and others on network) DR spawners activate immediately and render without issue.
    Send same render through backburner to the same workstation and the spawners do not activate at all.
    Screen shots attached.
    We were previously using Vray 2.4.04 and all was working fine
    Any help appreciated, Thanks
    Christiaan
    Do you get any warnings or error messages in the backburner server log?
      Hey Vlado,
      Thanks for the quick response. Nothing that seems out of the ordinary
      2014/04/16 11:19:14 INF Application is down
      2014/04/16 11:19:34 ERR Launcher: Timed out executing command:"C:\Program Files\Autodesk\3ds Max 2012\maxadapter.adp.exe" "-o" "ShutDown" "-l" "Info"
      2014/04/16 11:27:08 INF Receiving new job from 192.168.50.12
      2014/04/16 11:27:08 INF Job 'DR test' received and ready
      2014/04/16 11:27:08 INF Launching 'Autodesk 3ds Max 2012 (64-bit)'
      2014/04/16 11:27:22 INF 3dsmax adapter : Executing command line : C:\Program Files\Autodesk\3ds Max 2012\3dsmax.exe "-_pipe:179322478" -server "C:\Users\c.klaassen\AppData\Local\backburner\Serv erJob\DR test.max".
      2014/04/16 11:27:22 INF [ServerMessage]ProcessStarted processId=4120
      2014/04/16 11:27:22 INF 3dsmax adapter : [V-Ray] ================================================== ==========
      2014/04/16 11:27:22 INF 3dsmax adapter : [V-Ray] Console created, V-Ray Adv 3.00.04 for x64 from Mar 24 2014, 06:08:01
      2014/04/16 11:27:22 INF 3dsmax adapter : [V-Ray] Compiled with Intel C++ compiler, version 12.1
      2014/04/16 11:27:22 INF 3dsmax adapter : [V-Ray] Host is 3dsmax, version 14
      2014/04/16 11:27:22 INF 3dsmax adapter : [V-Ray] V-Ray DLL version is 3.00.02
      2014/04/16 11:27:22 INF 3dsmax adapter : Autodesk 3dsMax 14.12 is Ready.
      2014/04/16 11:27:22 INF New task assigned: 0
      2014/04/16 11:29:36 INF Received End of Job command
      2014/04/16 11:29:36 INF Application is down
      2014/04/16 11:29:56 ERR Launcher: Timed out executing command:"C:\Program Files\Autodesk\3ds Max 2012\maxadapter.adp.exe" "-o" "ShutDown" "-l" "Info"
      2014/04/16 11:44:04 INF Receiving new job from 192.168.50.12
      2014/04/16 11:44:05 INF Job 'DR test' received and ready
      2014/04/16 11:44:05 INF Launching 'Autodesk 3ds Max 2012 (64-bit)'
      2014/04/16 11:44:18 INF 3dsmax adapter : Executing command line : C:\Program Files\Autodesk\3ds Max 2012\3dsmax.exe "-_pipe:180339121" -server "C:\Users\c.klaassen\AppData\Local\backburner\Serv erJob\DR test.max".
      2014/04/16 11:44:18 INF [ServerMessage]ProcessStarted processId=5908
      2014/04/16 11:44:18 INF 3dsmax adapter : [V-Ray] ================================================== ==========
      2014/04/16 11:44:18 INF 3dsmax adapter : [V-Ray] Console created, V-Ray Adv 3.00.04 for x64 from Mar 24 2014, 06:08:01
      2014/04/16 11:44:18 INF 3dsmax adapter : [V-Ray] Compiled with Intel C++ compiler, version 12.1
      2014/04/16 11:44:18 INF 3dsmax adapter : [V-Ray] Host is 3dsmax, version 14
      2014/04/16 11:44:18 INF 3dsmax adapter : [V-Ray] V-Ray DLL version is 3.00.02
      2014/04/16 11:44:18 INF 3dsmax adapter : Autodesk 3dsMax 14.12 is Ready.
      2014/04/16 11:44:18 INF New task assigned: 0
      2014/04/16 11:46:19 INF Received End of Job command
      2014/04/16 11:46:19 INF Application is down
      2014/04/16 11:46:39 ERR Launcher: Timed out executing command:"C:\Program Files\Autodesk\3ds Max 2012\maxadapter.adp.exe" "-o" "ShutDown" "-l" "Info"
      These were the last 2 attempts
      Chris
        Hmm, and what about the V-Ray log file? We tested this here and it seems to work fine, generally. So we have to figure out what's the problem on your machine...
          ok. Where does the Vray Log file save to?
          Is it a separate file to one's created when rendering locally?
            Usually it's called vraylog.txt in the temp folder for the current user; however this may be changed in the .max file.
            Bset regards,
              Shall i email the Vraylog files to you? It says the upload limit is 20kb for text files?
                Yes, you can email it to vlado@chaosgroup.com
                  i've just sent them.
                  Would the port numbers be any different to what Backburner was using with previous versions? I only ask as this is a new tab in the DR settings page.
                  TCP/IP Port Numbers
                  Distributed rendering works over TCP/IP and requires the following ports:
                  Renderer type
                  Port number
                  Port type
                  Production renderer 20204 TCP/IP
                  Production renderer 20205 UDP
                  RT renderer 20206 TCP/IP
                  Port 20205 is only used by render servers to broadcast a message that they are ready to join an ongoing DR rendering.
                  Christiaan
                    Hi vlado
                    i kind of have a problem with dr as well.......
                    Being writting to support team but no solution.
                    dr works with backburner but one one sys takes part.
                    no hyperthreading takes part.
                    but with all the same setup and vray 2.4 all works fine
                    Please help if possible
                      Do you use the option to save the DR host list in the scene? It may be that it doesn't work correctly, but I'm looking into it now to check if this is the case.
                        Hi guys
                        I am totally existed....
                        Found my mistake.
                        All now works fine....
                        With a1 option
                        only one sys works throught backburner and no hyperthreading,
                        With q2 option
                        All sys work and also hyperthreading.
                        Render would take long to start as i call presets which were save in older v-ray versions......
                        I am extremely sorry to make all these mistakes and keep asking for help...
                        Love u v-ray guys for all the support.
                        Regards
                        savio alvares
                          Ok, that's good, but it might point to a problem with the "Save hosts to scene" option. Do you want to use only av1-av5 for rendering? Or the machine with BB has a different list of render servers?
                            i send all my render via av1 only.
                            and i use av1,av4,av5 for rendering.
                            The other sys are old one. so i dont use them for rendering any more.
                            Thanks alot
