3dsMax and Vray freezing on render end
  • 3dsMax and Vray freezing on render end
    Hello,
    I came across a problem today. After my rendering is finished, 3dsMax is freezing. The rendering is completed and the render progress windows already closed itself. But 3dsMax or Vray is still showing some CPU-Usage. The bad thing is that no image is saved... A bit frustrating as I can already see the result, but I have no chance to save the images.
    I'm on Max 2014 with Vray 3.00.3. I thought it was related to embree, but disabling that didn't help.
    Hm, if you upgrade to the latest official build (3.00.05), is the issue still there?
      Thanks for the info, will try.
      One thing I found out, it doesn't happen with low quality test settings.
        Yeah, isn't that always the case
          Updating to .05 solved the problem. Thanks again!
          Regards
          Oliver
