Vray RT and DR translucency different
  • Vray RT and DR translucency different
    Working on a translucent material RT looks like what I want but the render doesn't. No translucency in the render.
    What is going on?
Name:	RT_DR_transluceny different.jpg
    Simon
    I need a new signature
    Max2017.1 | Vray 3.70.01| win11
    ASUS Z790PLUS | i9 13900K | 64Gb RAM | Geforce GTX4070Ti
    Can you post the scene for this?
      Tried to PM you the file but couldn't attach it
      Anyway I've stripped anything sensitive from the file
      RT-DR_translucency different_01.zip
      Simon
        Thank you very much for the scene.
        It seems that the Translucency effect is not calculated properly by Vray RT - that's why the result differs.
        If you disable Translucency both Vray RT and Vray Production will produce a very similar result.
        I'm not aware if translucency is supported in Vray RT but I'll make sure that this is logged in into our bug tracking system.
          It should work fine in the CPU version at any rate, but still looking into it.
            It looks like we didn't export the translucency parameters to the RT; will be fixed for the next update. Thanks for the pointer!
              Btw, the RT was rendering as though translucency was set to "none", if you were looking to reproduce the same effect in the production renderer.
                thanks Vlado good to know.
                Simon
