Distributed Rendering default lights bug
  • Distributed Rendering default lights bug
    Just noticed that when using DR, deactivating all lights and shadows via global switches and just turning on default lights, it renders black. If i turn off DR it renders fine.
    I'm using 3.05.05
    not sure that's a bug, it's always been like that as long as I remember.
      My bad, didn't know about it
          How that could become not bug because of Your knowledge that it has been as long as You remember?
            "Default lights are not supported in DR mode and will not render. If you need any lighting in the scene, you should add it explicitly."
            from the Vray Manual. Distibuted Rendering Section.
              Maybe we should print a warning about this...
                it appears it'd worked, I so wanted it not being a bug..
