EnvironmentFog overrides DMC
  • EnvironmentFog overrides DMC
    If you, for example, put a noise inte the density slot of the vrayEnvironmentFog it looks like it overrides the noise settings in the DMC.
    Also checking the deep output makes it extremely slow and the memory goes through the roof. Is there any correct way to use EnvironmentFog with deep?
    Richard Blank
    www.haymakerfx.com
    I should probably read the help first
    Still struggling with the deep output...
    Richard Blank
    www.haymakerfx.com
      Ok, its not a good ide to use the deep output without a fog gizmo.
      Richard Blank
      www.haymakerfx.com
        Yes, it takes a lot of memory. Something that you can do is to add V-ray Option RE and play with the Deep merge threshold.
        Tashko Zashev | chaos.com
